Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 120
Thread: Will this intercooler fit?
  1. #81
    Nov 2007
    Actually, no..... APR style (for the Polo and MK4 GTI) is a 90degree design ..... straight through not common on Polo's. I'd do 1, but it would require an intake manifold with the intake on the other end.
    Example of the classic and most efficient Air to Air IC straight through design ....
  2. #82
    Feb 2007
    Brisvegas
    Nov 2007
    Quote Originally Posted by VWindahouse View Post
    Awesome, can it go both ways? $$$?
  4. #84
    Feb 2007
    Brisvegas
    Sure can bud. Looks like it will be around $600 US when it gets released. Here is the teaser link
    VWVortex.com - *** 034Motorsport - Transverse 1.8T Intake Manifold Teaser! ***
    Massively increased flow
    Or you can just do this
    Yep it's a Polo!
  5. #85
    Nov 2007
    It is now on my shopping list ...
  6. #86
    May 2011
    Albury, NSW
    That would make it a lot easier to find a custom cooler and dayum it looks good!
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
  7. #87
    Jan 2009
    blankedy
    OT with the intercooler differences, I see how many rows and the length of the rows as a key difference.
    Sharky, I'm surprised you are seeing such the low temps given how short the cooling bars(?) are.
    Given all this bending, etc happens under pressure, I'm unsure how much difference doing the 180 in the end tank vs through the bars would make. If you look at the standard XR6T intercooler, it does something quite similar.
    Testing should be interesting, hopefully will yield some usefull data.
  8. #88
    Oct 2010
    Melbourne, VIC
    Sorry but how is this not a 180 degree flow shift (90 + 90 just like the others)?
    My concern with this sort of design and the plumbling required is increased lag from the greater air volume between the turbo and the inlet manifolf.
    Resident grumpy old fart
  9. #89
    Point Cook, Vic
    The air does not have to turn 180 degrees inside the endtank on sharkies unit.
    It does a 90 degree bend. through the cooler then another 90 degree bend.
    Would be interesting to compare the flow and whether the 180 degree design generates turbulence or restriction
    FOLLOW US ON FACEBOOK
  10. #90
    Quote Originally Posted by Tim View Post
    So what we are saying here is that 90 + 90 doesn't make 180?
