Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 91 to 100 of 120
Thread: Will this intercooler fit?
  1. #91
    Point Cook, Vic
    No!
    What we are saying is that not all changes in direction are created equally.
    FOLLOW US ON FACEBOOK
  2. #92
    I can see both sides of this argument and I reckon providing the end tanks have a large enough capacity, room for the air to change direction without hitting too much of a dead end, then whether it is single or dual pass will make very little difference.
  3. #93
    Oct 2010
    Melbourne, VIC
    That proviso is where the discussion currently sits!
    Anecdotally, there isn't much pressure drop across the SEAT FMIC but I await the results of the dyno day with bated breath (and suggest that the group purchase be put on hold until this is settled with meaningful measurements of the pressure and temperature drops )
    Resident grumpy old fart
  4. #94
    Point Cook, Vic
    Im with you there. If the end tanks were big enough I guess it would flow in a similar fashion to 2 separate 90 degree bends. Id love to see how it all worked in reality.
  5. #95
    You cannot judge the flow by looking at the outside of the intercoolers end tanks either.
    The reason the APR one works so well is the internal vanes in the end tanks that are cast in to direct the airflow - unfortunately it adds considerably to the costs:
    APR - High Performance Development for Audi, VW and Porsche Vehicles.
  6. #96
    Feb 2007
    Brisvegas
    Guy, any chance of getting a Polo along on Saturday with the APR cooler??
    You busy Eddy?
  7. #97
    Aug 2012
    Sydney NSW
    Install instructions for Seat:
    http://forgemotorsport.co.uk/media/intssibpinst.pdf
    The pipework instructions should all be relevant.
  8. #98
    Sep 2006
    Tweed Heads
    Quote Originally Posted by VWindahouse View Post
    You busy Eddy?
    Hoyhoy.
    Yeah.
    Anthony me will be busy spectating you chaps.
    Now I have a choice of 3 vehicles to drive up there, which one will I take.
    Hooroo.
  9. #99
    Jan 2012
    Bentleigh East, Melbourne, Vic
    Looking forward to seeing the real life test this weekend.
    I may be lookng at this rather simplistically, but the larger the area of the ic, the lower the temp. However the potential for more back pressure.
    So would there be a formula for whats beter... Lower temp, less boost ( cause of pressure) or higher temp, more boost.
    The forge unit is not good, since it has too much pressure drop, but given the charge temperature drop, shirley it is still beter than the smic.
    The same hold true for larger ic's, although there will be a point of diminishing returns.
    However lets see this weekends runs. I trust guy will be monitoring charge temp/ pressure vs. Kwatw
    Polo 9n3 GTI
  10. #100
    Feb 2007
    Brisvegas
    Quote Originally Posted by Eddy View Post
    Hoyhoy.
    Yeah.
    I'd be happy to kick in some coin to see the wee Blue Girl run or maybe Guy will shout you for being such an awesome customer
    Either way it would be brilliant to have an APR intercooler to do some comparisons with.
    Cheers Eddy!
