Results 1 to 10 of 13
Thread: whistling sound under boost
    Apr 2017
    victoria
    hey everyone!
    last night went for a drive i dont drive the polo all that much these days, was quite cold outside too. at about 20psi car makes a high pitched whistling sound i have no idear what it could be what do you guys think?
    iv been running a stage 2 map and have been for quite awhile
    2010 polo gti 9n - stage 2
    nsw
    I'd bet a beer that its the exhaust mani to turbo gasket. Heat blankets off the charge pipe so you can see what you are doing and then I think a 16mm. You should be able to get away with bending the heat shield out of the way or its a bolt at each side of the head that holds that on. Because of the ribbing on the top of the exhaust mani a spanner rarely works at the ****ty angles you have to work at but if you use a short socket, 3/8th drive and a uni joint with extension you can get onto the bolts. If they are loose, crank them as hard as you can and you may be lucky and the gasket hasn't burnt through. Replacing the gasket isn't hard if it still whistles from the same spot later on. Use a pick to drag the old one out and slide the new one into place. You'll need to remove the steel charge pipe from the back of the motor and the heat shield to do that though. Worth getting a spanner onto any of the exhaust mani to head nuts that you can reach too.
    Apr 2017
    victoria
    thanks samb im going to have a look see now ill let you no how i go
    Oct 2017
    Wodonga, Vic
    And replace the bolts with grade 12.9 cap heads and use nordlocks right Sam
    nsw
    ha ha yep. Thats my recipe!
    Apr 2017
    victoria
    alright so i spent my time making sure everything is airtight from tip to gasket, turns out it was the airbox whistling! after deleting secondary air intake system long ago i used some black duck tape to plug the airbox hole that fed into the air pump well that piece of tape had started to come off so i removed the old tape and put new stuff on and bingo! fixed! no more whistle~ just getting my arm around the back of the engine to the manifold was hard enough let alone getting a spanner in there very happy it wasnt the gasket and so glad im a slack **** =p sometimes
    thanks guys!
    nsw
    tape!! too easy.
    Apr 2017
    victoria
    come to think of it, made a really cool whistle too! google said that it was my turbo failing geez i was worried lol
    Oct 2017
    Wodonga, Vic
    Quote Originally Posted by triplej3 View Post
    pffft - never trust Dr Google....
    any air that goes through that hole is unfiltered straight into the turbo so do something more permanent than tape. I siliconed a little bit of alloy plate over it from the inside
    Apr 2017
    victoria
    your right simon iv ditched the dodgy tape idear and went for a 32mm rubber chair tip from bunnings, really tight fit and i used a hose clamp too. cost $3.60
    TIC 32mm Black Round Rubber External Chair Tip - 4 Piece | Bunnings Warehouse
