Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 46
Thread: Where to now? POWERRR
  1. #31
    Apr 2006
    VW Race HQ - Sydney
    They will be pressed in .
    I still dont understand why everyone goes to so much effort to get 20-30kw more than a regular ko4 ?
    Water-meth , carbon fibre bits , some lighter wheels etc will give you the same rate of acceleration ..
    If your going to do a big turbo I would start at gt2871r as a minimum . A nicely built 2.0l bottom end with a set of cams and a good intake . Anyway , my 1.8t is finished , just need to finish off some coolant pipework and intake before it will roar to life .
    LSD and sticky tyres is a must if you want traction , as are some stiffer mounts and decent suspension .
    Bug_racer supports the rebellion of the euro revolution
  2. #32
    Apr 2006
    VW Race HQ - Sydney
    Put some prices on that Seb. ^^^
    Which bit ? Engine rebuild ? Turbo kit ? Water meth ?
    Then there is the question of what hardware is already on the car !
  4. #34
    Aug 2012
    Sydney NSW
    Quote Originally Posted by Bug_racer View Post
    how much to install a wavetrac?
  5. #35
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by Redliner View Post
    How old is the gearbox ?
    If the car makes decent power I prefer changing the syncros to mk4 GTI types as they are more durable for more power .
  6. #36
    Aug 2012
    Sydney NSW
    2006 95000kms. I will probably change the clutch to a stage two ECS unit at the same time. Are you based in Sydney?
  7. #37
    Sep 2006
    Was thinking of using a different gearbox as i know i will want more power one day, was thinking of a o2m 6 speed or something.
    Guess it is a good option to use the MK4 syncros, is it expensive ?
    MODS- TOO MANY
  8. #38
    Apr 2006
    VW Race HQ - Sydney
    Id do a full rebuild , pending on how good your gears , ring and pinion etc are .
    Ive had my shop pretty much since I left VW Racing in 2004 in Sydney , out in Parramatta
  9. #39
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by vwthunder View Post
    Id draw the line from an 02J to 02M once you go over 400hp
  10. #40
    Assume it's got nothing done to it. You could list it all:
    Engine rebuild
    turbo kit
    FMIC
    Exhaust and DP
    water meth kit
    gearbox internals/LSD
    Is he looking at $10K or more?
