Originally Posted by
Buller_Scott
Regarding grip, I found that my koni adjustables had my front tyres screeching from 1st-2nd gear under hard acceleration, when set on 4/5 clicks of stiffness. However, no such issue when on full soft - obviously, they were hooking up much more effectively, which means that TOO much stiffness can be counter productive when playing with damping settings,
gavs was talking about chassis stiffness. Besides Eddy's little blue girl, the other car to look at would be jasonc23 - his Winton lap times have plummetted since fitting the front and rear Ultra Racing under braces.
I agree with Stuwey, though - without AWD, the best solution is an LSD or TBD.
Resident grumpy old fart
