Put some prices on that Seb. ^^^
They will be pressed in .
I still dont understand why everyone goes to so much effort to get 20-30kw more than a regular ko4 ?
Water-meth , carbon fibre bits , some lighter wheels etc will give you the same rate of acceleration ..
If your going to do a big turbo I would start at gt2871r as a minimum . A nicely built 2.0l bottom end with a set of cams and a good intake . Anyway , my 1.8t is finished , just need to finish off some coolant pipework and intake before it will roar to life .
LSD and sticky tyres is a must if you want traction , as are some stiffer mounts and decent suspension .
Bug_racer supports the rebellion of the euro revolution
