Not too worry, all sorted was a piece of piss to do in the end..
Regs MR-GTI
Where did you run your Vacc line for the Boost gauge !!!
Hi all, well a mate of mine from England has sent me a little gift.. I have installed everything except the boost ref line, as I'm having a hell of job trying to locate a Grommet to get the line from the inside the car to the engine bay..
I know that heaps of you have gauges, if you don't mind, please advise me exactly where you managed to get it through to the bay..
Pix would be nice...
Ohhh.. BTW.. what is the standard boost in the Polo ????
Regs MR-GTI
Regs MR-GTI
Where abouts did you go through? I'm trying to run a small diameter power cable through and cannot find any locations to do so.
Hey bud,
On the passenger foot well you will see a small wire going through the firewall.
It goes through a massive grommet, I just drilled a new hole underneath it and fed the Vacc line through very easy.
The simplest way is to take you air box out so you can see under the ECU in the engine bay and then you will see where the grommet is in the engine bay.
Hope this helps.
Regs MR-GTI
