Will they fit the Beeza?Originally Posted by Golf Loon
they look great!pretty good price too, thats what i was going to pay for just a normal set up for my Pogo
cheers Loon
Those look interesting...but I'd urge a little caution, as the spring rate quoted -- FRONT SPRING RATE: 7.0 kg/mm -- REAR SPRING RATE: 5.3 kg/mm -- (that's around 400 & 300 lb/in respectively) seems fairly ...er...actually, very stiff! I had a look on clubpolo.co.uk, and one of the guys there suggests the standard Polo (not GTI) is 225 & 180. If that's the case, then on typical Australian roads she'll jump around like a frog in a sockOriginally Posted by Golf Loon
Edit: I'll just temper what I said, having seen, GolfMan, that your Pog is a TDI, and therefore a little heavier at the front end
Surely as they are adjustable, the spring rates will change too.
I think also the picture is just a file pic and not of the actual set you will get.
The springs may be progressive, ie, each coil may compress slightly differently, but the overall rate is fixed. The adjustment will be in the dampers
The springs are not adjustable, their rate is fixed. You can get springs that are wound to give a soft intial ride but stiffrn up after a certain amount of compression.
If your still looking for a decent solution for your Polo give Dragan a ring at InMotive (KW Agent for Australia) Dre is extremely helpful and has a number of options for your car. http://www.inmotive.com.au
Cheers Al
timbo these coils arent for my TDi (thats my dads car) These coils are for my 97 1.6![]()
stiff is orite, much preffered to what ive got now
Whats your budget. Do you have the cash now? Probably get you a weitec kit landed for $800.
