Results 1 to 4 of 4
Thread: Wheels - will they fit
    Jun 2011
    Hi guys
    Just wondering if the polo will fit 17x7.5 +48 wheels
    They should fit the 7.5 width but don't know about the offset.
    Apparently I have read that we can go to a 7 inch width with +43 but the extra ~12mm width plus the 5mm offset may scrub?
    I'll check on offset calc but wondering about clearance of the struts and guards
    Thanks in advance
    Sep 2006
    Your going to need big spacers to run a +48 offset, also the Sabaru Center bore is wrong, guess it depends on the wheel.
    At the end of the day you can make just about anything fit, if you have the $$. Coilovers, camber etc
    I am in the process of fitting +48 offset, I am running 15mm spacers tho, and plan to have some camber on the front
    Feb 2007
    Brisvegas
    Can get hubcentric adapters to knock the 73.1mm centrebore down to 57.1mm no problems... Check with your insurance re: spacers as I know that unless they are factory fitted (i.e. Porsche) they are illegal in QLD... Not sure about other states
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
    Feb 2008
    Spacers and adaptors are illegal in Vic too...
