Your going to need big spacers to run a +48 offset, also the Sabaru Center bore is wrong, guess it depends on the wheel.
At the end of the day you can make just about anything fit, if you have the $$. Coilovers, camber etc
I am in the process of fitting +48 offset, I am running 15mm spacers tho, and plan to have some camber on the front
