Results 1 to 10 of 14
Thread: Wheel and tyre size fit
    Anyone know from experience what non VW ie Advanti 17x7 wheels and tyres 225/45/17 fit or too wide/high? Cheers Al
    Feb 2007
    Brisvegas
    Would depend on the offset Al. But I do know that no one has managed to fit a 225/45R17 on a polo yet. I would suggest 215/40R17 as the biggest you can fit without fender work, but once again that would depend on the wheel offset
    Sep 2006
    Tweed Heads
    Hoyhoy.
    I know that 225/45/16's fit.
    Hooroo.
    Quote Originally Posted by Eddy View Post
    Hoyhoy.
    What spec rims Eddy?
    Jan 2009
    blankedy
    If you're lowered, 215 / 40's are all you want to play with without work. Even then, some plastic needs some rubbing to sit reasonably with stance at the rear.
    Work to top-mounts can make a huge difference, but not a light undertaking.
    Erskineville, NSW
    Hoyhoy.
    And they would be a full 25mm less in diameter than 225/45r17 wouldn't they?
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Hoyhoy.
    P.S. I'm running 225/45/16 (rims = 16 x 8 with 35mm offset) for the track which is a common semi size (but not in a road tyre) & is a lot smaller in height than the 215/45/17 & only 5mm higher than the 215/40/17.
    Hooroo.
    Thanks for the replies and shared knowledge guys. Will not be going to attempt that size fitment. Cheers Al
    Nov 2012
    WA
    Semi on topic, but what's the biggest tyre you can fit on stock rims?
    08 9n3 Polo GTI
    Mods: heaps
    Jan 2009
    Quote Originally Posted by rgvlee View Post
    That would depend on one's definition of biggest tyre, but as far as I can tell:
    In terms of diameter, 235/80 R16 is the largest tyre that can be fitted on 6.5J x 16 wheels.
    In terms of width, 255/70 R16 is the widest tyre that can be fitted on 6.5J x 16 wheels.
