Results 1 to 6 of 6
Thread: Wheel nuts
    Eltham, Victoria
    Wheel nuts
    Hey guys,
    what length, and more importantly, diameter wheel nuts does the Polo require?
    Will this differ with alternate wheels?
    cheers
    Length shouldnt change to much, your allowed some play.
    If you stick your bolt through your orginal wheel while its off the car and measure the distance it sticks out, that is how much you want on your new wheels...
    OR there should be the diameter of the bolt in length holding it in place (so in my car, M14 bolts, there should be 14mm (or close enough) holding it in the hub.)
    Be more worried about the seat type. OEM wheels have 'ball' seats where as after market might have tapered ones...
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Oct 2009
    Canberra ACT
    Do you have a pic of these Ball seats vs tapered one?
    06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
    Jan 2009
    blankedy
    Standard length should be about 27, 28mm (length of the threaded part). Cheap ones are aweful, nice can be expensive. There are good ones from places like ECS, but the freight is a killer.
    Our bolts are pretty generic, you can ask your local wheel / tyre shop for a look at what they have.
    Jan 2009
    blankedy
    first pic that came up on Google
    Oct 2009
    Canberra ACT
    Thanks for the pics noone. much clearer
