Are S3 brakes 312mm (same as mk4 r32?)? If so they will fit.
Sent from my SM-T815Y using Tapatalk
Hey guys,
Can anyone please tell me if these wheels will fit on the polo without an issue.
Car is standard height but has an S3 brake upgrade installed.
Its a bit of a drive to get them so i wanna make sure i get it right.
Thanks in advance.
Audi TTmk1 Ronals 7.5j /205/50r17s suit mk4 Golf
The tyres are a smidge bigger than the 205/55/16 that I run on my car, which are just about as big as you can go. I get a little bit of rubbing on the inner guards at full lock, if I had any less offset then I'd get a lot
You need to find out the offset of those wheels, the extra 25mm of width has to go somewhere
Chances are they will rub somewhere, if you bought them and went down to 45 profile tyres (when the 50's wear out) they'll fit better
Ended up finding another set of wheels. Thanks for your help guys
