Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: What's a good rpm to shift to save fuel?
    Jan 2008
    Sunshine Coast
    If you are really serious, get a boost gauge. Whenever boost is rising, so is fuel use. It teaches you a LOT about smooth driving, and where the engine is most efficient. Changing up at low revs, and expecting the engine to cope with that under anything but gentle acceleration, and it will be bosting and using more fuel than you realise. I consider a boost gauge essential for any of the diesels equipped with a DPF, as any off boost efforts is producing DPF blocking soot.
    Seems like a rational excuse for a cool mod to me!
    Melbourne, Vic
    Only problem is its hard to drive this car light, you just want to give it a squirt every time you take it out, only starts sounding good around 3 - 4k+ revs
    But when im being a tight arse on the fuel doing the eastern fway in the morning to work, i usually try and keep it down revving as long as possible as you literally use no fuel on the down rev to about 1400rpm, below that it starts to use a bit of idling juice
    Other than that its not bad, doing the fway/hoddle st run in bull**** peak hr traffic it consumes around 8.9 - 9.3L , and i see a lot of you guys out there to, fair few polo's do the morning run
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Greg Roles View Post
    <snip>
    Me too - I'm just loathe to start tapping/welding the exhaust manifolds while the cars are still under warranty (not to mention routing cables, mounting gauges...)
    Do you think an ODB reading device that displays the inlet manifold pressure would do the job?
    I can understand reigning in a GTi would be frustrating. For better or worse, I bought an econobox so that's how I drive it (outside cruises).
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. Tigar VR6 fuel problem
    By JET-28L in forum Mk3 Golf & Vento
    Last Post: 30-01-2007, 02:32 PM
  3. Diesel Fuel lines
    By smithy010 in forum Diesels
    Last Post: 18-11-2006, 06:04 PM
  4. help.. fuel problems!
    By mollins in forum Mk1 Golf
    Last Post: 07-05-2006, 02:21 PM
  5. Getting fuel in the carbs
    By worm in forum Mk1 Golf
    Last Post: 22-04-2006, 05:25 PM
