Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: what tire or tyre pressure ?
    Jun 2008
    central coast
    Smile what tire or tyre pressure ?
    HI all can other gti polo owners tell me is it better to have 40 psi or 35 psi 40 seems to give a firm ride will the higher pressure make my tires last longer?My car has the original tires.
    Feb 2008
    You are probably better off running between 32 to 38PSI in your tyres COLD. Don't run around on your tyres then check the pressure. the heat that has built up in your tyres through running on them will give you a false reading, and you can tend to over inflate your tyres causing too much wear in the center of the tread.
    Jan 2008
    The recommended on the plaquard is too low. Run between 38 and 40 for the best handling.
    The difference in tread wear from 35-40 is minimal.
    Jun 2008
    central coast
    Hey thanks man ill try 38 cold i dont drive it that often got it booked in for 24 month service this fri.i might see how good they are and check if they pump it up i have a digital gauge ill take with me .
    Alfred Cove, WA
    I found running at 40psi dead cold has got me over 52000km on stock tyres.
    Jun 2007
    i am running mine at 42 at the front and 40 at the back.. seems to give a better handling then 38. my butt meter kinda feel it on braking comparing the two.
    Oct 2006
    Quote Originally Posted by Adam View Post
    IIRC that's what is recommended inside the fuel cap.
    Quote Originally Posted by Flaps View Post
    You sure about that? I did the conversion from BAr to PSI and it was more like 38/35
    Oct 2006
    Lol yeah you could be right. Last time I looked was 2006.
    Jan 2008
    The recommended pressure is for COMFORT, not HANDLING.
    Use 38-40ish for handling. Wear shouldn't be much different.
