Originally Posted by
leegil
The offset is ET45. I know they fit as they are the same as the Lavinhard FIN advertised at Ozzy Tires (they also have a pic of the polo GTi with them installed). I had a chat with Brad from Ozzy and he confirmed the fit
Can you confirm that every thing clears with the 45mm offset once you get it all mounted?
I didn't think there would be enough backspacing with the wide tyres/rims in that offset. Or will you be running spacers?
Importing Speedy wheels from the US is just weird
I would have thought that they could special order the different colour for you.
Resident grumpy old fart
