Results 1 to 10 of 17
Thread: What are the best cheapish lowering springs for a 2008 Polo GTI?
    Jan 2015
    Franklin, ACT
    I got a 9n3 Polo about a month ago and it gets a lot of body roll in corners with stock springs and shocks. I figured the cheapest way to make it corner a bit better could be some stiffer and lower springs. I was just wondering if anyone had any horror stories or problems when lowering their car, or if there were any springs that are better value than others. I'm looking for a 35/40/45mm lowering spring and hoping the cost will be less than $300.
    Thanks
    Quote Originally Posted by hayden2235 View Post
    Thanks
    H&R and Eibach do springs but they aren't the best when combined with stock shocks
    I'd save up for a proper kit/coilovers. Or get a rear anti roll bar.
    nsw
    Yeah you're pretty well locked into a few european brands for springs. Add in there Weitec (now defunct I think) and ST by KW (which I suspect are just weitecs rebranded). Factor in fitting cost especially on the front struts if thats not something you'd normally do ( 3hrs labour) and you may have to double do that job if you decide to add uprated dampers later. As long as you are aware of, and will drive around their limitations, rear anti roll bars really do transform the car and kill off alot of the roll. You may be happy with just that.
    Nov 2012
    I have some very cheap weitec springs for sale... About $100 plus postage or pickup from Liverpool Nsw. Google part numbers for details.
    Jan 2015
    Franklin, ACT
    Thanks guys. I'll go with the anti-roll bar and see how that goes. If I wanted to lower the car (from an aesthetic point of view) do you think lowered springs would ruin the ride or just not improve the handling?
    Jan 2015
    Franklin, ACT
    By how much would those springs lower the Polo?
    nsw
    Bullet Fast, I've PM'd you.
    Jan 2015
    New Zealand
    You'd have to do your own research but I think about 15 - 20mm. I have just bought H&R from Germany via ebay seller offroadmeister, Took about 8 days to my door, for about NZ$250. They are supposed to be good for a 30 - 35mm drop. Will soon find out how accurate that is but guess it depends how much the old springs might have sagged.
    Oct 2010
    Melbourne, VIC
    Or you could get out the angle grinder....
    Resident grumpy old fart
    Jan 2009
    Ruin.
    If you want it to handle, check the front lower control arm bushes and replace if they're knackered and add the rear sway bar. There is very little geometry play in these things, so somewhat limited in that regard. Springs alone, the car is under dampened and floats all over the shop, you'll notice the secondary movements, particularly at highway speeds on B roads, it's awful IMO. Others are more accepting of the ride, but I'd advise against, particularly if you enjoy punching corners.
    Daily: 2010 VW Jetta Highline
