I got a 9n3 Polo about a month ago and it gets a lot of body roll in corners with stock springs and shocks. I figured the cheapest way to make it corner a bit better could be some stiffer and lower springs. I was just wondering if anyone had any horror stories or problems when lowering their car, or if there were any springs that are better value than others. I'm looking for a 35/40/45mm lowering spring and hoping the cost will be less than $300.
Thanks
Yeah you're pretty well locked into a few european brands for springs. Add in there Weitec (now defunct I think) and ST by KW (which I suspect are just weitecs rebranded). Factor in fitting cost especially on the front struts if thats not something you'd normally do ( 3hrs labour) and you may have to double do that job if you decide to add uprated dampers later. As long as you are aware of, and will drive around their limitations, rear anti roll bars really do transform the car and kill off alot of the roll. You may be happy with just that.
I have some very cheap weitec springs for sale... About $100 plus postage or pickup from Liverpool Nsw. Google part numbers for details.
Thanks guys. I'll go with the anti-roll bar and see how that goes. If I wanted to lower the car (from an aesthetic point of view) do you think lowered springs would ruin the ride or just not improve the handling?
By how much would those springs lower the Polo?
Bullet Fast, I've PM'd you.
You'd have to do your own research but I think about 15 - 20mm. I have just bought H&R from Germany via ebay seller offroadmeister, Took about 8 days to my door, for about NZ$250. They are supposed to be good for a 30 - 35mm drop. Will soon find out how accurate that is but guess it depends how much the old springs might have sagged.
Or you could get out the angle grinder....
Resident grumpy old fart
Ruin.
If you want it to handle, check the front lower control arm bushes and replace if they're knackered and add the rear sway bar. There is very little geometry play in these things, so somewhat limited in that regard. Springs alone, the car is under dampened and floats all over the shop, you'll notice the secondary movements, particularly at highway speeds on B roads, it's awful IMO. Others are more accepting of the ride, but I'd advise against, particularly if you enjoy punching corners.
Daily: 2010 VW Jetta Highline
** All information I provide is probably incorrect until validated by someone else **![]()
