Without ripping too much off the engine; we also cleaned the throttle body. looked pretty good, but gave it a quick spray, a bit of oil came out, pretty normal IMO.
also removed 2 plugs (3&4) - there was a misfire on cylinder 3 - checked them and both were fine, also swapped coils 3 and 4 in case the problem moved.
Besides a boost/vacuum leak I wouldn't want to guess, maybe PCV or the crank-case ventilation?
Happy to do some more logging when you need it mate.
