Results 1 to 8 of 8
Thread: water meth on a gti
    Dec 2010
    jhb, south africa
    water meth on a gti
    Hi
    Please share pics of your installs and what bottle you used and where you located it
    Jan 2009
    blankedy
    I think WM is generally only viable on BT setups. Happy to see otherwise.
    Dec 2010
    jhb, south africa
    I know a few guys who are running it on k03s on polos and seat cupras here in SA, it makes a difference of between 10-20 hp depending on the tune
    ---------- Post added at 10:30 AM ---------- Previous post was at 08:23 AM ----------
    kit looks like this
    Jan 2009
    blankedy
    Right, guess I'm not up with the WM movement.
    I'm thinking it helps in summer, but does less in winter?
    Feb 2007
    Brisvegas
    It's usually injected just before or into the TB and becomes part of the combustible air mixture so season won't effect it. But you will get the usual winter cold denser air benefits and therefore a bit more power.
    ---------- Post added at 08:54 AM ---------- Previous post was at 08:50 AM ----------
    Here is a very popular kit for the 1.8t
    Snow Performance: Products
    Awesome stuff but they won't ship the mixture OS last time I inquired
    Dec 2010
    jhb, south africa
    With water meth, there is multiple gains.
    You get cooler intake temps with the water
    You get higher octane cos of the meth
    The kit I have has a power button so I can switch it on and off as I please
    I will be running revo stage 2 soon so I will set performace 1 with no meth, performance 2 with meth and performance 3 with aggressive settings and high octane
    ---------- Post added at 08:10 AM ---------- Previous post was at 08:09 AM ----------
    I found my intake temps to be in the high 70s(celcius) pre fmic, post fmic its now in the high 30s, with wmi it will be under 20s
    Feb 2007
    Brisvegas
    Holy crap, sounds pretty good. Where do you plan on installing the nozzels mate?
    Dec 2010
    jhb, south africa
    The fmic i bought was used, it had a bung for the wmi already but i sealed it up when i fitted it, i will make a new boost pipe for map sensor and wmi, the pipe is the one you see on the left of the pic
    ---------- Post added 31-12-2011 at 09:33 AM ---------- Previous post was 30-12-2011 at 10:09 AM ----------
    Here's a better pic
    The pipe on the left isnt too pretty for my liking so I plan on changing that
