I have the problem you describe at the moment, I would put my bets on the drain tubes.
Open your bonnet and check in the back corners, mine was chock full of leaves, blow it out.
I opened the sunroof and blew compressed air down the front two drain tubes to clear them until I could hear the air coming out of the corners I mentioned, this seems to have fixed the problem.
I would have water in the footwells without fail after rain, now there's nothing ...in the front.
I still have water pour out the rear seatbelt holes and all over the seatbelts, etc.
I think I've found the fix, but it's not a quick fix. It involves removing all the interior trim and replacing the OEM drain tubing that fails after time with better tubing.
Try the front drain tubes first, it will more than likely fix it for you, but check the rears as well
