Page 51 of 56 FirstFirst ... 414950515253 ... LastLast
Results 501 to 510 of 559
Thread: Vwthunders build thread (finally)
  1. #501
    Sep 2006
    Quote Originally Posted by seangti View Post
    Troy, you got the IC piping sorted now? I don't foresee mine popping again, Jimmy did a great job on the pipe work, and put a fixed bracket on the side to tie it down.
    Sorry to see the bumper/wheel gaurd like that. Hope it hasn't caused other damage.
    Bumper was fine and front is all back together minus one wheel arch liner lol
    Not fussed about the intercooler piping as i will have this on soon
    MODS- TOO MANY
  2. #502
    Jan 2009
    Quote Originally Posted by vwthunder View Post
    Nice. So a custom piping job on the way.
    Daily: 2010 VW Jetta Highline
  3. #503
    Sep 2009
    brisbane
    Nice one, be interested to see if your boost goes up as there should be less pressure drop with a single pass intercooler. I'm pretty sure we're running the same/very similar cores. Mine handled a run up mt nebo/glorious on the weekend with no obvious heat soak, I think you'll be pleased
  4. #504
    Sep 2006
    Quote Originally Posted by Lito View Post
    Awesome, more boost
    Combine that with the water meth injection Thinking of doing direct port injection, I know eddy has done it so i wont be the first
    MODS- TOO MANY
  5. #505
    Sep 2006
    Tweed Heads
    Awesome, more boost
    Hoyhoy.
    Just be careful Troy about the Direct Port Injection.
    I have the smallest nozzles available (25cc) in the inlet manifold, I have a code = PO135 coming up, which is a Co2 sensor.
    Just this afternoon I done some mucking about & found that the code was only coming on when I had the direct port ones hooked up.
    I had these start up @ 15lb boost which is my second stage watermeth system, with a bit of adjusting I now have this second stage coming in @ close to 20lb & it seems to have improved the code error.
    There's plenty out there that will sell ya multiblocks for the direct port set up, but most have the smallest nozzles of 60cc.
    I'm fairly certain that these 60cc ones will be way too much for our little donks.
    Hooroo.
  6. #506
    Sep 2006
    Thanks Eddy
    I will be using the USRT kit of course , oh they do 30cc as the smallest now and the 50cc also. Im waiting for them to get the 30cc in stock.
    Where did you have them on the runners, closest to the plenum or closer to the head ?
    MODS- TOO MANY
  7. #507
    Looks tough as fark, Troy.
  8. #508
    Sep 2006
    Quote Originally Posted by Deadpool View Post
    Thanks Jon
    MODS- TOO MANY
  9. #509
    Sep 2006
    Tweed Heads
    Thanks Eddy
    Hoyhoy.
    This should give ya an idea of what I done Troy.
    Hooroo.
  10. #510
    Sep 2006
    Oh forgot to say thanks Eddy for the pics
    MODS- TOO MANY
