Page 49 of 56 FirstFirst ... 394748495051 ... LastLast
Results 481 to 490 of 559
Thread: Vwthunders build thread (finally)
  1. #481
    Oct 2010
    Melbourne, VIC
    That looks immaculate Troy. But then your car always does.
    Really good to see your car getting the recognition it deserves
    Resident grumpy old fart
  2. #482
    Oct 2006
    congrats troy! looking awesome as usual man.
  3. #483
    Sep 2006
    Bit of a update
    Had a few things brewing for a while now, whilst the Frankenturbo is ok, I need that little bit extra, so why not purchase a SEM intake manifold. I have read that people have seen 20+whp which is quite amazing for just a bolt on manifold, so i decided to order one direct from SEM.
    The manifolds come with the throttle body on the left or right side, so to get rid of the bad setup design of the dual pass intercooler i opted for the manifold with the throttle body on the passenger side. This means i will need a new intercooler also, so i ordered one from PWR, as they are supposed to be some of the best.
    A few, well one negative mechanic from Sydney said it wont fit, it is going to be quite tricky, but nice to do something that no one has done
    MODS- TOO MANY
  4. #484
    Keen to see this all done. Good luck, Troy.
    Sent from my eyePhone in the year 3014.
  5. #485
    Sep 2006
    Updated my list of mods, im sure i have forgotton a few things
    Its a very long list
    Dont know if i would want to go through and add it up tho
    Outside
    Tinted windows
    Cupra front lip
    Honeycomb grills
    Black front badge
    Black rear badge
    Rhino roof bars with bike attachment
    Hella Black tail lights
    Stubby antenna
    Projector headlights with DRL's and HID kit installed
    OMP tow strap
    Aerocatch bonnet pins
    Suspension
    Whiteline front lower control arm bushes
    Powerflex front control arm bushes
    Powerflex Steering rack bushing
    KW V3 coilovers
    Whiteline rear swaybar
    Ultra racing rear under body brace
    Whiteline front adjustable swaybar linkages
    Kmac adjustable Camber/Caster tops
    Wheels
    BBS LM wheels 17X7.5 & 17X9 205/40/17 and 215/40/17 Kumho KU31's
    Team Dynamics Pro Race 1.2 17X8 wheels with 215/45/17 Hankook RS3's
    VW Detroit Denver 17" 5X100 Federal 595 215/40/17
    VW Tocatta 17" with Dunlop 215/45/17 Racing Slicks (hard compound)
    Simmons FR17's 17X8 fully polished (rebuilding at the moment)
    Brakes
    Front
    Porsche Boxster callipers
    ECS 334mm 2 piece rotors
    Hawk HP Plus pads
    Braided brake lines
    ATE Blue Racing fluid
    Wheel Stud conversion
    Rear
    ECS 310mm 2 piece upgrade
    Hawk HPs pads
    Engine and Drive train
    Eurojet 3inch dumppipe
    Custom Catback stainless exhaust with Xforce Varex muffler
    Frankenturbo
    Giac K04 tune
    386cc injectors
    Oem TT225/S3 maf housing and sensor
    Custom fabricated aluminium TIP
    PWR intercooler with 2.5 inch piping
    Froge 007 DV with spring kit
    Forge front strut brace
    Forge short shift
    42dd cable bushes
    Billet shifter bracket bushings
    APR dog bone insert
    Phenolic intake manifold gasket
    DeatschWerks DW65v intank pump
    Audi R8 oil cap
    BMC CDAintake
    Full river, small battery
    Euro Valve cover (polished)
    Integrated Engineering valve cover bung
    Integrated Engineering coil pack adapters
    Red TFSI coil packs
    SAI delete with Forge blanking plate
    42dd catch can
    Gruven parts Billet dipstick and dipstick tube
    Troques –AN fittings
    Polished fuel rail
    SEM intake manifold, smoothed and polished
    Polished Throttle body
    Polished engine mount
    Polished Hood Lifts
    Deleted wiper washer
    Deleted coolant/overflow
    Battery moved to boot
    Inside
    Dash cubby
    Edition 30 flat bottom steering wheel
    Recaro Sportster CS seats
    Custom Fabricated roll cage by Fabraications
    OMP 4 point Harness (driver)
    Boost gauge
    SWG vent gauge holder
    Custom Carbon Highlights
    Forge Big Knob
    Pioneer AVIC F900BT double din headunit
    Alpine SPX front splits
    Scan Gauge
    MODS- TOO MANY
  6. #486
    Jun 2013
    South Africa
    So much of want...
    Dude your car is spectacular, been watching this build quietly!
    want to see the results with the new intake mani!
    10' 9n3 Polo GTI
    |6000k HIDS Mains/Fogs|NewSouth Performance Boost gauge + SWGpod|Custom Induction|K&N|ATE Drilled & slotted Discs|
    SEAT Sport Strut Brace|Unitronic Stage 1+|76mm Downpipe|FORGE TIP
  7. #487
    Sep 2006
    Time for a bit of a update
    I posted this in the "What did you do to your polo today" section
    My bent Kmac strut tops
    With thanks from Eddy i received some advice on springs
    Going to a Kings race spring rated at 250lb
    Im interested to see how it feels, I will be fitting them in a few days, cant wait
    Oh also Kmac sent me some custom spring perches to suit the new springs
    MODS- TOO MANY
  8. #488
    Jan 2009
    What rate were the KW springs? Please keep me posted on your thoughts and if you can provide any lap time data once you've lapped it. Say cornering g's or speed.
    Id meant to msg you during the week. I will hold on to the Kmac's for the meantime. Some mates are getting wicked lap times on mk6's with 3deg neg camber on the front so I might have to follow the pack. Plus some noises in the front strut tops on the silver car so good to have some spares.
    Daily: 2010 VW Jetta Highline
  9. #489
    Sep 2006
    Eddy told me the KW's were 175 pound springs in the front, so going up to a 250 pound spring, hoping its not too harsh for daily driving
    Interested to see how it turns in, i am currently running 3 degrees neg camber at the front for street Its not that good for traction taking off tho
    Quote Originally Posted by seangti View Post
    MODS- TOO MANY
  10. #490
    Sep 2006
    More goodies arrived
    Got the PLX wideband kit and a separate boost module so i can run both on one gauge
    MODS- TOO MANY
