Page 43 of 56 FirstFirst ... 33414243444553 ... LastLast
Results 421 to 430 of 559
Thread: Vwthunders build thread (finally)
  1. #421
    Quote Originally Posted by vwthunder View Post
    First session out, well the car was not running that well only boosting to 18psi (N75 problem i think) so i took it easy and managed to get a PB on the 3rd lap. Tires felt awesome, really predictable. Had a bit of a miss/stutter going from 3rd to 4th.
    Attachment 5626
    Did you end up sorting out the boost issue?
    As for the track, more practice
    Cheap, Fast, Reliable. Choose two.
  2. #422
    Oct 2010
    Melbourne, VIC
    + try to find what the optimal 'hot' pressure range is for the tyres (the tyre dealer should know) and make sure you're within the range before any more suspension fiddling. 33psi cold sounds quite high for a semi-slick or even an ultra low profile, high performance tyre.
    Resident grumpy old fart
  3. #423
    Sep 2006
    Quote Originally Posted by Stuwey View Post
    Yes i worked it out
    N75 must have been slowly dying. Car has not felt the same the last few months so I cranked the wastegate a little. I was thinking it had come loose and backed itself off, car feelt fine now.
    Day before track day N75 only allows 18psi.
    Does track day with 18psi
    Gavin posts spare N75 (thanks Gav)
    Installs spare N75 and car boost like a mofo !!
    Guessing i need to back off on the wastegate now
    MODS- TOO MANY
  4. #424
    Sep 2006
    Quote Originally Posted by kaanage View Post
    I bought my self a nice gauge last week (to play around with pressures) Should arrive soon !!
    MODS- TOO MANY
  5. #425
    May 2012
    Gauge is a great purchase.
    I use Hankook Ventus TDs at the track. Cold I have them at 29psi, depending on the track temp they go up to 35-37. 36 hot is the optimum temp for these babies.
    I had quite a few boost issues this year. You just know something's not right, especially when Dyno numbers are lower than expected and I'm running about 30psi boost. First to go was the DV! Then replaced the N75 and PCV. I've just done another PCV by the looks of the white smoke I'm getting at WOT. Now looking into getting a few spares and a possible oil pressure system like Accusump that APR have currently. Piece of mind too.
  6. #426
    brisbane
    Quote Originally Posted by grandturismo View Post
    i have one i have just removed from mine mate, only done 18,000 clicks if you need something to tied you over. i was keeping hold of it incase it ever goes back on...
  7. #427
    May 2012
    Quote Originally Posted by guile View Post
    Should fit right? Yeah that would be great.
  8. #428
    brisbane
    pm me mate so i don't clog up thunders thread.
    nice build by the way, i will be keeping my eye on this as planning to track my car when i can. all the hints and tips i can pick up are a bonus...
  9. #429
    May 2012
    Sure, and thanks Troy for the use of your thread for this little exchange
  10. #430
    Sep 2006
    Thanks to Pierre, Andrew and Saeed for the Pics from DOVW last weekend
    MODS- TOO MANY
