+ try to find what the optimal 'hot' pressure range is for the tyres (the tyre dealer should know) and make sure you're within the range before any more suspension fiddling. 33psi cold sounds quite high for a semi-slick or even an ultra low profile, high performance tyre.
Resident grumpy old fart
