Daily: 2010 VW Jetta Highline
Nice one, be interested to see if your boost goes up as there should be less pressure drop with a single pass intercooler. I'm pretty sure we're running the same/very similar cores. Mine handled a run up mt nebo/glorious on the weekend with no obvious heat soak, I think you'll be pleased
Hoyhoy.
Just be careful Troy about the Direct Port Injection.
I have the smallest nozzles available (25cc) in the inlet manifold, I have a code = PO135 coming up, which is a Co2 sensor.
Just this afternoon I done some mucking about & found that the code was only coming on when I had the direct port ones hooked up.
I had these start up @ 15lb boost which is my second stage watermeth system, with a bit of adjusting I now have this second stage coming in @ close to 20lb & it seems to have improved the code error.
There's plenty out there that will sell ya multiblocks for the direct port set up, but most have the smallest nozzles of 60cc.
I'm fairly certain that these 60cc ones will be way too much for our little donks.
Hooroo.
Thanks Eddy
I will be using the USRT kit of course , oh they do 30cc as the smallest now and the 50cc also. Im waiting for them to get the 30cc in stock.
Where did you have them on the runners, closest to the plenum or closer to the head ?
MODS- TOO MANY
Looks tough as fark, Troy.
Driver Motorsport Tuned | Melbourne Car Meets | Insta: @VLNTVADERR
Oh forgot to say thanks Eddy for the pics
MODS- TOO MANY
