Ideally I'd like to put the Team Dynamics on for the track, the height in the rear seems perfect for the BBS's so should be fine with clearance. Felt pretty good on the drive today
For the moment, the car's just the daily to and from work, albeit I've got to swap the two front tyres to something better than these Sailun Altrezzos the previous owner put on for a roadworthy probably. I was spinning up to 5th gear in the wet with them haha cleaned up the filthy fender liners when I checked today.
Anyway, this is the tricky part like always. I've got two shim sets so can maybe run two different styles for the rear. I don't mind taking apart and swapping them out a few times if it'll provide some benefit on the day.
So do a Street setup with one set and aggressive track on the other.
Obviously the front can be easily switched up. Pulling the ball joint further out from the LCA giving more neg camber
And then running the castor position up top, or turning the head and running strong camber.
As for bracing etc, pretty much running all Ultraracing braces and the whiteline rear swaybar on the hardest setting as opposed to the UR solid brace. *OCD Euro brace for dailying, and the extra UR boot brace when on the track.
Just slowly trying to nail everything out, probably aesthetics too (cup stuff), and do a big turbo build for fun next.
Salvage Auction Catalogue – Southern Salvage MID-RANGE BID NOW (TAS, VIC, SA, WA) – Lane 0 – Manheim National Online, National
Also coming up on Thursday morning. Hopefully get back what I put in otherwise I'll part it out.
Car's finished, would just need the reinspection from VW and then a VIV again. Just needs someone who knows what they're doing
