Results 1 to 4 of 4
Thread: VW Polo on 3 cylinders only
    sydney, NSW
    Guys
    My Polo 2003 was going ok but all of the sudden it start shaking and it is only on 3 cylinders now. Can anybody suggest a good mechanic (place). I've taken it to VW itself before but I found it too expensive, any advice will be greatly appreciated.
    Oct 2010
    Melbourne, VIC
    Is yours the 1.4?
    Camden GTI always gets good comments up there. Coilpacks maybe the issue.
    Resident grumpy old fart
    Oct 2009
    Canberra ACT
    Sounds like exactly the same problem I had with my 9N3 GTI. Turned out it was the coil pack for one of the cylinders
    06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
    sydney, NSW
    Thanks for the replies guys, any ideas how much should I expect to pay.
