Just received my Ross-Tech VAGCOM.
I scanned and got this fault. I know I had this fault before... the circulating button does work, but sometimes refuses at times randomly. I copy and pasted below.
Do you know what I should do? This fault was present throughout the ownership, but because the button worked it never really was sorted. Apparently it's really sensitive and causes this at times??
What else can I do with my VAGCOM?Anything I can do... I want to check my steering wheel weight again, but don't know - just want to make sure it's in GTI mode.
Thursday,18,June,2009,19:39:51:59879
VCDS Version: Release 805.4
Data version: 20090602
Chassis Type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 37 44 45 46 56 76
VIN: WVWZZZ9NZ6Y140363 Mileage: 40830km/25370miles
Address 01: Engine Labels: None
Part No: 06A 906 032 TL
Component: 1.8l R4/5VT 0040
Coding: 11500
Shop #: WSC 14389
WVWZZZ9NZ6Y140363 VWZ7Z0E2888745
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
Part No SW: 6Q0 907 379 AE HW: 6Q0 907 379 AE
Component: ESP 8.0 front H02 0001
Revision: 00000000 Serial number: 00000000000000
Coding: 0000269
Shop #: WSC 00788 785 00200
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Q0 820 045
Component: Klimaanlage X0840
2 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
29-10 - Short to Ground - Intermittent
28-10 - Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 00BK BN-SG. 1S34
Coding: 25742
Shop #: WSC 00788
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 18 AIRBAG VW51 0P 0008
Coding: 12600
Shop #: WSC 00788
Address 17: Instruments Labels: Redir Fail!
Part No: 6Q0 920 823 N
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 01144
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0B7L GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 00788
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10120
Shop #: WSC 00010
Address 45: Inter. Monitor Labels: None
Part No: 6Q0 951 171 C
Component: Innenraumueberw. 0020
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 65 Komfortger? 0002
Coding: 00018
Shop #: WSC 00090
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 6Q0 035 152 A HW: 6Q0 035 152 A
Component: Radio BVX 005 0004
Revision: 00005000 Serial number: VWZ1Z5E8970715
Coding: 0040400
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
End ---------------------------------------------------------------------
06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
