Damn it there any other way to get this look cleaner? i have measurements from blocks 004 / 020 / 115.
Group A: '004 Group B: '020 Group C: '115
RPM Voltage Temperature Temperature Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization RPM Load Absolute Pres. Absolute Pres.
TIME TIME TIME
Marker STAMP /min V °C °C STAMP °KW °KW °KW °KW STAMP /min % mbar mbar
394.48 2800 14.21 87 27 394.79 0 0 0 0 394.18 2800 16.5 1000 1020
395.39 2800 14.28 87 27 395.69 0 0 0 0 395.09 2800 48.1 1000 1050
396.29 2800 14.21 87 27 396.6 0 0 0 0 395.99 2800 48.1 1000 1100
397.2 2800 14.21 87 26 397.5 0 0 0 0 396.9 2800 43.6 1000 1090
398.1 2800 14.21 87 26 398.41 0 0 0 0 397.8 2800 42.9 1000 1090
399.01 2800 14.21 87 26 399.31 0 0 0 0 398.71 2800 34.6 1000 1070
399.91 2760 14.28 87 26 400.22 0 0 0 0 399.61 2800 27.1 1000 1040
400.82 2760 14.21 87 26 401.12 0 0 0 0 400.52 2760 32.3 1000 1030
401.73 2760 14.21 87 26 402.03 0 0 0 0 401.42 2760 44.4 1000 1060
402.63 2760 14.28 86 26 402.93 0 0 0 0 402.33 2760 45.1 1000 1090
403.54 2760 14.21 86 26 403.84 0 0 0 0 403.23 2760 47.4 1000 1090
404.44 2760 14.21 86 25 404.74 0 0 0 0 404.14 2760 54.9 1000 1130
405.35 2800 14.21 86 25 405.65 0 0 0 0 405.04 2800 55.6 1000 1140
406.25 2800 14.21 86 25 406.55 0 0 0 0 405.96 2800 55.6 1000 1140
407.16 2800 14.21 86 25 407.46 0 0 0 0 406.85 2800 55.6 1000 1140
408.06 2800 14.21 86 25 408.36 0 0 0 0 407.76 2800 55.6 1000 1140
408.97 2800 14.21 86 25 409.27 0 0 0 0 408.67 2800 48.9 1000 1120
409.87 2880 14.14 86 26 410.17 0 0 0 0 409.57 2840 112 2190 1390
410.78 3040 14.21 86 29 411.08 0 0 3 3 410.48 2960 190.2 2260 2450
411.68 3200 14.14 86 32 411.98 3 0 3 3 411.38 3120 191.7 2220 2480
412.59 3320 14.14 86 35 412.89 3 3 2.3 5.3 412.29 3280 188.7 2190 2330
413.49 3440 14.14 86 39 413.8 2.3 3 2.3 5.3 413.19 3400 183.5 2160 2260
414.4 3560 14.21 86 42 414.7 2.3 2.3 2.3 5.3 414.1 3520 179.7 2140 2220
415.3 3680 14.14 86 46 415.61 2.3 2.3 1.5 4.5 415 3640 178.2 2160 2230
416.21 3800 14.07 87 50 416.51 1.5 1.5 1.5 4.5 415.91 3760 173.7 2160 2200
417.11 3880 14.14 87 51 417.42 1.5 1.5 0.8 3.8 416.82 3840 139.8 1740 1620
418.02 3880 14.21 87 52 418.32 0.8 0.8 0.8 3.8 417.73 3880 108.3 1370 1330
418.93 3880 14.28 87 51 419.23 0.8 0 0.8 3.8 418.62 3920 68.4 1000 1330
419.83 3840 14.21 87 47 420.13 0 0 0 0 419.53 3840 39.8 1000 1230
420.75 3800 14.07 87 45 421.05 0 0 0 0 420.43 3800 39.1 1000 1130
421.64 3760 14.07 87 46 421.94 0 0 0 0 421.34 3800 112.8 1290 1400
422.55 3720 14.21 87 42 422.85 0 0 0 0 422.25 3760 18 1000 1130
423.45 3640 14.21 87 40 423.75 0 0 0 0 423.15 3680 12.8 1000 1030
424.36 3520 14.21 87 39 424.66 0 0 0 0 424.05 3560 12.8 1000 1020
425.26 3440 14.28 87 39 425.56 0 0 0 0 424.96 3480 12.8 1000 1020
426.17 3360 14.21 87 38 426.48 0 0 0 0 425.87 3400 12.8 1000 1020
06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
Excluding those using 'genuine' cables, which eBay cable are you guys using?
Have you looked through this thread? Pretty sure I linked a document on 'how to'...
Your data is a bit random Kiwi, what we want to see is a single run taken from below boost (say 1500 rpm) all the way to redline, WOT in 3rd or 2nd up a hill if you don't have the space.
Also, the less data you log at the same time, the higher the sample rate can be.
I'm using a cable that came from the UK from memory, was about $30. Does not allow clearing codes. Its blue, USB attachment and did not come with software. Took a bit of fiddling to get it doing what I wanted.
Feel free to PM me if / when you get yours. There is a few bits required to get the most out of it, probably easiest over the phone.
today was a hot day, with 36+ degree celsius - so made some intake temp logs:
1520 48
1600 47
1760 47
1920 46
2160 45
2360 45
2600 45
2880 45
3200 44
3560 44
3960 43
4400 42
4720 41
5040 40
5400 40
5680 40
6000 40
6280 40
6520 40
6320 39
4880 39
4760 39
4960 40
5120 41
5240 41
5400 41
5520 41
5680 42
5800 42
- this is a run started in 2, accelerated, changed to 3rd and accelerated again...
- with the car stopped the intake temp was 51 celsius
do you have FMIC? It seems really good the intake temps. The one I have put up there, was when it was around 19 degrees celcius, and it was peaking at 52. I only have factory side mount intercooler though. So your intake temps are very good.
I have the Forge FMIC.
I've posted before (post #10) an intake log taken when the outside temp was around 20 degrees or so, but that was before remap.
Want to start getting VAG-COM logs for my car, which cable do i need to buy?
So many on eBay:
vag-com, Cars, Bikes, Boats, Tools, Volkswagen items at low prices on eBay.com.au
Edit: And is the software freeware?
