Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 70
Thread: VAG-COM Logging
  1. #51
    Point Cook, Vic
    yah get a nice log in third gear from low rpm to as high as you dare take it.
    FOLLOW US ON FACEBOOK
  2. #52
    Jan 2009
    blankedy
    Thanks Rosonic. Don't know what I am looking at with some of that data.
    The airmas looks about right, I hit about 165 or something at peak.
    I'm looking at Logging block 120 now. This gives estimated Torque, but I don't know if this will alter from tune to tune...
    From this you are apparently supposed to be able to work out the HP as well, but like a dyno, I think you should use it for a reference rather than bible.
    Measurements would correlate to flywheel numbers.
    Lots of runs in various gears overlayed. Although the data is messy, if I can get some feedback as to the accuracy (+/- 20%) then this is quote a helpful tool if we can get a few people posting results.
    Ross-Tech have a spreadsheet already made up for this: Ross-Tech: VAG-COM: Diagnostic Procedures have a look at the Block 120 logging attachment.
  3. #53
    Jan 2009
    Bucharest, Romania
    The yellow line is injection time - in mili seconds (right y-axis), brown line is engine load - in % (left y-axis).
    So if this statement is correct:
    Group 002 usually shows air mass in g/s. Your peak airflow should be roughly 0.80 times your horsepower. So, if you have a stock 150 hp 1.8T, expect around 120 g/s
    you should have about 206.5hp at 165g/s
  4. #54
    Jan 2009
    Bucharest, Romania
    Tried to mark the boost vs air flow - on the compressor efficiency map:
    I've put dots for 2600,3000,3500,4000,4500,5000,5500,6000 rpm on the chart taken from BorgWarner.
    don't shoot me if I did it wrong - - I'm new at this.
  5. #55
    Jan 2009
    blankedy
    Woah, if that is correct, hats off to you for producing some real world data that can really be understood as to the efficiency of the turbo relative to your / our car.
    Very cool.
    As for the air flow, these guides are just guides, I would think they would be roughly + / - 20% of actual values as the power can be gained in other ways, but it does indicate that the car / tune is doing what it should.
  6. #56
    Jan 2009
    Bucharest, Romania
    Here's my logging of block 120:
    Don't know how precise this is, but on the stock car it gave almost the same results like on the dyno.
  7. #57
    Sep 2006
    Wow didnt know you could do that
    Might have to try to log CH120 tomorrow night
  8. #58
    Jan 2009
    Bucharest, Romania
    Here's a EGT graph - from block 034 (cat temperature)
    it's a run in 4th gear then shifted to 5th and accelerated until 6000rpm.
    Any opinions on this ? Is the temperature too high ?
  9. #59
    Jan 2009
    blankedy
    Sorry mate, could not say.
    From what I've read, 850 is the upper limit for the Cat efficiency temp range. My understanding is if you go higher, you'll throw a code.
    I think if you were looking to cook something, the ECU would try to compensate for it by pulling timing, changing AFR's or adjusting boost, etc.
    Quote Originally Posted by RoSonic View Post
    Something like that. There are different ways to get power and advancing timing can add power without changing the airflow.
    Its just a guide that the car is operating as expected, more of a guide than a definative answer.
  10. #60
    Jul 2007
    Auckland, NZ
    REVO Stage 2 - data logging is done, but is it not possible attach any files here?
    I have a 110k excel file.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
