![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Carrot
Gavin, I'll try again tonight when I get home. If I could get a jump lead to the starter motor, I'm not sure I understand what your train of thought is?
I think he means by going under the car (it's quite open if you remove the under tray), not through the bonnet.
Resident grumpy old fart
