Yeah the way the UR rear anti roll bar fits has its pro's and cons. If you have to fiddle with dampers or springs it won't have to be unbolted every time like the whiteline - possibly better that way for track guys. But changing hardness settings on the whiteline is dead easy. Also you can't just say that the whiteline is stiffer overall as its 20mm versus 18mm for the UR. The UR has shorter lever arms and no drop links(which usually makes bars stiffer) but doesn't have the part of the bar that actually twist torsionally solid mounted like the whiteline, which I would have thought would tend it toward being softer in that respect. Also are they the same steel quality? You could only really tell which is stiffer by driving them back to back.
But yes, rear bars are very worth it. Probably the single biggest bang for buck suspension item you could fit. It will turn in better but lift off oversteer can creep in at the other end. I don't think the latter is much of a biggy though, its pretty hard to get out of shape even when you're trying. A big emergency swerve in the wet when you're already cornering might be more of a prob.
