Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Ultra Racing RSB / Strut Brace Questions
    Jan 2009
    In the context of a softly sprung car I can't see flex being great as it'll be absorbed within suspension movement (IMO). Obviously, as the car is firmed up, bracing becomes more relevant.
    If your budget was say $100 a tyre and a strut bar ($200) or $150 a tyre, I'd go the $150 a tyre.
    Daily: 2010 VW Jetta Highline
    May 2015
    NSW
    thanks for the feedback guys.
    Sent from my SM-P550 using Tapatalk
    Jan 2014
    Clontarf, Queensland
    Quote Originally Posted by seangti View Post
    I'd have to agree with Sean. After moving to coilovers the chassis flex is very noticeable. I'm interested to test top and bottom bracing to see how it helps.
    Mods >1
    nsw
    couple of questions about the forge front strut brace. Are you meant to tighten it to pull the strut towers together or does it expand? Can you get to the airbox with this brace or is it a remove job like the UR?
    Jan 2009
    Quote Originally Posted by sambb View Post
    Neither, a strut tower bar is to be unloaded like a sway bar. You should simply be able to undo the strut bolts and remove with minimal hassle. You're otherwise loading the strut top bolts diagonally which they aren't designed for. The stiffness comes once tightened.
    Its a remove bar job to access factory air box. 6 bolts and she's off.
