Page 8 of 23 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 226
Thread: Ultra Racing Brace group buy
  1. #71
    Jan 2009
    blankedy
    ok, so i'm becoming indecisive...
    I want better ridgidity, but unsure what route to take.
    Already have the forge front upper brace and both whiteline sways.
    was going to go with the front underside brace and the rear upper brace but I'm concerned about loosing my bootspace which i use daily ATM.
    so, does anyone have an idea of how well the rear lower brace might work?
    I guess most of us are going in fairly blind and basing the outcome on other cars, etc.
    I cant imagine the mid brace doing much, love to hear why its a good idea.
    There does not seem to be any info on the manufacturers website about installation, etc, has anyone seen anything on this, being used in polo, cupra, etc elsewhere?
    Any opinions would be better than my experience in this area.
  2. #72
    Feb 2007
    Brisvegas
    Quote Originally Posted by spraycanmansam View Post
    Def up for front lower brace, rear lower brace and front sway.
    Lock those in.
    I'd love to know if the center brace gives you more exhaust clearance than the stock piece? If it does id be up for one of those too.
    Confirmed, thanks Sam. From the pictures of the stock v's UR middle brace I would say they're fairly similar.
  3. #73
    Aug 2012
    Sydney NSW
    Confirming front top strut brace only. Had a good look today and it looks as though rear top strut brace won't clear my sub in the back.
  4. #74
    Jan 2009
    Hi anthony, are these braces (the lower ones) confirmed as direct bolt on, DIY fitting? So no drill holes required.
    Noone - with regards to the rear lower brace, I'm still dubious as I don't know exactly where it's bolting in to. I'd guess that upper brace will provide greater rigidity, or perhaps better worded, greater impression of rigidity than the lower brace. My reasoning for this is that the strut tops are further from the flex point (being the floor/chassis) than the strut bottoms, therefore greater flex is likely at the tops than the bottom.
    I'd like to go the upper brace as somepoint, but it needs to be easy to install/remove which UR doesn't appear to be.
    Daily: 2010 VW Jetta Highline
  5. #75
    Feb 2007
    Brisvegas
    Quote Originally Posted by Redliner View Post
    Cool, thanks mate.
    Quote Originally Posted by seangti View Post
    Hey Sean, yes they are supposed to be direct bolt on. Luis has a list of dodgy ebay sellers in his email signature which have fitment and quality issues, but the original stuff is meant fit correctly.
    As for the bottom rear brace, from the photo it bolts directly to the chassis in two places each side where the suspension beam axle also bolts to the chassis. I have very high hopes for this one.
  6. #76
    Oct 2006
    Quick question, do you think your group buy will extend to other models or is it pogo only?
  7. #77
    Jan 2009
    Quote Originally Posted by VWindahouse View Post
    Thanks for clarifying.
  8. #78
    Feb 2007
    Brisvegas
    Quote Originally Posted by peedman View Post
    Not to sure mate. I would think Luis would extend the offer for other forum members if you asked.
  9. #79
    May 2012
    Perth, WA
    Confirm rear lower bar
    cheers
    06 Polo TDi
  10. #80
    Oct 2009
    You can confirm me for a front upper brace.
