Page 21 of 23 FirstFirst ... 111920212223 LastLast
Results 201 to 210 of 226
Thread: Ultra Racing Brace group buy
  1. #201
    Quote Originally Posted by gavs View Post
    You should be using a minimum grade of 8.8 on the bolts in suspension components. If you can't get 8.8, get 12.4.
    So Gavs, how does that translate in plain English to the nice shiny stainless steel bolts supplied and it seems were not suitable for this application? Cheers Al
  2. #202
    Jun 2008
    Ringwood, Victoria
    Throw them and go to you favourite fastener reseller and buy the same size bolts in grade 8.8 steel.
  3. #203
    Oct 2010
    Melbourne, VIC
    American Fastener - ASTM, SAE, and ISO Grade Markings
    Grades of Bolts
    http://www.roymech.co.uk/Useful_Tabl...s/Strength.htm
    Grade 8.8 in any size you are likely to need should be readily available from any bolt shop. It's the high tensile ones that are tough to find in some sizes.
    Resident grumpy old fart
  4. #204
    Jan 2009
    Cheers for the heads up on the bolts. It'd be worth relaying to UR.
    Daily: 2010 VW Jetta Highline
  5. #205
    Quote Originally Posted by seangti View Post
    So do Ultra Racing need to show all of us their serious about the quality of the products they supply and offer some replacement bolts suitable for the intended use? Cheers Al
  6. #206
    There's nothing wrong with the quality of the bolts and to be fair none of the braces are full on structural items. They are highly unlikely to come off in my opinion.
    In the interest of a neater install, I'd be using bolts that aren't overly long and I'd fit some locking nuts.
    What I don't really like is the monster holes that are in the rear brace.
  7. #207
    May 2012
    Perth, WA
    agree
    the holes in the rear brace are awfully awful
    need to get some bigger washers
    and I had a cross-threaded bolt on the brace today when I try to change them to a set of high tensile bolts and nuts
    now I have 3 new bolts and nuts with an old one on the rear brace
    can't take it off, can't tighten it
    any suggestions?
    06 Polo TDi
  8. #208
    Can you do a picture of the cross threaded one. So I can see the location.
    Quote Originally Posted by TDIfan View Post
    agree
    any suggestions?
  9. #209
    Jan 2009
    Is the rear lower and front lower brace intuitive on where to mount?
  10. #210
    Oct 2009
    Has anyone fitted the front braces yet from the current group buy?
    I bought a front brace about 4-5 months ago and I had to modify it to fit, curious to see if these will require the same. I also took it off for regular street driving and it was rubbing on the subframe and making unpleasant scraping sounds.
