Results 1 to 7 of 7
Thread: Tyre rotations
    Mar 2007
    VIC
    Tyre rotations
    I guess this is more of a general question, but how often should I rotate the tyres? And do I rotate them including the spare?
    Jun 2007
    i am planning on rotating mine soon (after exams) i have just done 20k.
    i am not sure about rotating the spare, because, then you'll have different tread wear on the spare tire corner? (correct me if i am wrong)
    Mar 2007
    Hinchinbrook
    Quote Originally Posted by poloplayer View Post
    nope.. i wouldnt rotate the spare... keep it nice and new, that way in a few years if you sell it private the spare will look as new which will show you have taken care of the car.. ie: not driving on the spare for 100k's before fixing the puncture... My 2 cents anyway.. mario.
    Jul 2005
    to be technically correct you are supposed to rotate your spare as well.. that way all tyres get wear from all corners of the car and should be approximately even in tread wear. I think the standard rotation time is 10000km's.
    Aug 2006
    do u need allignment or balance after rotation?
    Adelaide hills, SA
    Quote Originally Posted by 1DUB2C View Post
    Since it is front wheel drive car I'm rotating every 5,000km including spare. There is good reason for that when the car will be 10 years old or more and tyre was never used it doesn't have to be in usable condition when you get the puncture.
    I always put 2-4 psi more at the front tyres just in case I have to brake hard (under heavy braking the centre of the tyre colapses and tyre has contact with the road only with the edges of the tread only).
    Jul 2005
    you shouldn't need a balance or alignment after rotation. all you are doing is moving the balanced wheels/tyres from one corner to another so this would not alter the suspension geometry etc.
