Currently running on 2.2 (fr) & 2.1 (rr) bar, so far felt too loose. Gonna try 2.8 & 2.6 bar later on. Do you guys know what our car alignment spec? Camber, toe? Is the caster adjustable?
One thing to remember also is that different brands recommend differing pressures. I ran my Contis at 40 ... but I'm running the Marangonis at 36. The Marangonis have a stronger sidewall than the Contis and 36 gives a little extra flex. Generally ... I'd take the tire manufacturer's advice ... for optimum performance & wear ... they should know best.
Dave
Don't set your expectations too high about front camber adjustability -- there's virtually none to be had![]()
2015 White German SUV
2013 White German hatch
2011 Silver French hot hatch
2008 TR Golf GT TDI DSG
Can't you use shims?
FOR SALE
"VW GTI" QLD Prestige Plate
Shims? What's that? Did you guys running on adjustable suspension & front pillow ball mounts? Supposed it can adjust camber with that right? I'm finding the car kinda wash wide at corners, got to do lots of left-foot braking just to get it neutral with ESP off of course
