Results 21 to 30 of 31
Thread: Tyre Pressure
  1. #21
    Kuala Lumpur
    Currently running on 2.2 (fr) & 2.1 (rr) bar, so far felt too loose. Gonna try 2.8 & 2.6 bar later on. Do you guys know what our car alignment spec? Camber, toe? Is the caster adjustable?
  2. #22
    Essendon
    Quote Originally Posted by firdausasri View Post
    I believe I've read something about the toe being adjustable, but not the camber. Not 100% sure.
    Sunroof // ICT Tint // Seats // Steering wheel
  3. #23
    Mar 2007
    One thing to remember also is that different brands recommend differing pressures. I ran my Contis at 40 ... but I'm running the Marangonis at 36. The Marangonis have a stronger sidewall than the Contis and 36 gives a little extra flex. Generally ... I'd take the tire manufacturer's advice ... for optimum performance & wear ... they should know best.
    Dave
  4. #24
    Kuala Lumpur
    Quote Originally Posted by max_croft View Post
    Max,
    The front cambers are adjustable, but not too sure about the rears coz of the semi independent setup
  5. #25
    Nov 2006
    Don't set your expectations too high about front camber adjustability -- there's virtually none to be had
    2015 White German SUV
    2013 White German hatch
    2011 Silver French hot hatch
    2008 TR Golf GT TDI DSG
  6. #26
    Nov 2006
    Georges Hall
    Max,
    Er no they're not.Only adjustment on the front is for toe.
    Rear is a beam,not "semi independent"? and has no camber/toe adjustment.
  7. #27
    Jan 2008
    Can't you use shims?
  8. #28
    Feb 2008
    Quote Originally Posted by MACCAA View Post
    Ok.....How are you supposed to adjust Castor, and Camber for when you do a wheel alignment?? Just dosn't seem right.
  9. #29
    Jun 2007
    Quote Originally Posted by tosspot View Post
    Yes you can, Whiteline make them for the Polo GTI. I tried them, although they toed out too much, so took them out.
  10. #30
    Kuala Lumpur
    Shims? What's that? Did you guys running on adjustable suspension & front pillow ball mounts? Supposed it can adjust camber with that right? I'm finding the car kinda wash wide at corners, got to do lots of left-foot braking just to get it neutral with ESP off of course
