Results 11 to 20 of 31
Thread: Tyre Pressure
    Jan 2007
    Quote Originally Posted by MissVuks View Post
    Thanks Golf Houso
    No worries, now here comes the fun part, experimentation !
    Feb 2008
    I tend to run 38 to 40 PSI all round.
    Lora, just remember to play with your pressures when the tyres are cold. Once they are warm, the air in the tyres expands, some times at different rates,thus giving you a higher reading, so it is better to do this when the tyres temps are all the same when cold.
    Jan 2008
    Cremorne, Melbourne
    yeah i run at approx 38psi all round. it's a good pressure for both comfort and handling. my car certainly does not bounce around the place and my handling is very good....so, i'm happy with it and it's what i'll be sticking to.
    in australia, people tend to run their tyre pressure at a bit less than in the fuel cap (on imported cars) due to our climate and the quality of our roads.
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    Jun 2006
    Orange NSW
    The other thing you guys need to remember is tyre wear.
    Too little pressure and your tyres will wear on the outside, too much and they wear in the centre. So you have to find a happy medium for that too.
    40 up front and 38 rear sounds about right on a polo with those tyres. more in the front because of the weight distribution. .
    Essendon
    I'm currently running 35 all round and very happy with the grip. At 40, I felt a little unsafe on roads with tram lines in the wet.
    Jan 2007
    Quote Originally Posted by max_croft View Post
    With the increase in tyre pressure, the centre of the tyre rises and as described earlier by Preen increases wear. It also means that water moves much much better across the tyre due to the wider surface and higher center, so i can't see why your car would perform worse with higher PSI in the wet when it should be the opposite.
    Feb 2008
    Quote Originally Posted by Golf Houso View Post
    Because with the center of the tyre being raised, it may present better water dissipation, but it also means less of the tyre tread face is in contact with the road, which as you know equates to less grip.
    Jan 2007
    Quote Originally Posted by Blitzen View Post
    Yes that too, but even the manual suggest to increase PSI during heavy loading or wet weather.
    Feb 2008
    Ahh, fair enough...I understand about the heavy loading, but that is weird about the wet weather, and goes against everything I have been taught.
    Jan 2007
    Yeah thats what I thought as well until I few people told me otherwise and I had a look at the manual, at least I thought I read it in the manual
