Results 1 to 10 of 17
Thread: Tyre OD size and their effect on the speedo
    Nov 2007
    It is time to upgrade my tires and am looking at 215-45-17 or 215-40-70 based on info that 215s are about as wide as you can go on without rubbing.
    205-45-16 (standard) is 591mm Overall diameter (OD)
    215-40-17 is 604mm OD
    215-45-17 is 625mm OD
    No, as we all know the Polos all overread by about 8kmh at true 100. Will larger diameter tyres cancel out the overread or make it worse ?
    Any info would help.
    Thinking of either Toyo Proxes R888 or Federal 595RS semi-slicks.
    Alfred Cove, WA
    larger diameter will make the speedo more accurate at 100..... to a point.
    Sep 2006
    Tweed Heads
    Hoyhoy.
    I had my speedo checked by a professional & he came up with a 9% over read at different speeds. So if you add 9% to 591mm it comes to 644mm to get a true reading.
    Hooroo.
    Nov 2006
    Georges Hall
    Be careful of fitting larger diameter tyres to correct speedo error.You'd be surprised how much it can knock performance.
    Had slightly larger tyres on a previous car,really noticed the difference every time I put the stockers back on...
    May 2007
    Burleigh Heads, Qld
    As MACCAA said, larger (or smaller) diameter tyres/wheels really knock things about.
    Even a small difference either way is VERY noticeable. Particularly off the line.
    Go smaller and your gearing gets rooted. Go larger and it feels sluggish off the line and noticeably slower to accelerate.
    Don't do it.
    Mar 2006
    South Hobart Tasmania
    All depends on your off set and width i guess.
    I am running a 205/40/17 595.8mm Diameter.
    I dont think a 215 would fit very well my rims have an offset of 32 which pushes them right out to the gaurds. looks the good but yeah u get a little stretched look.
    This is a set of TT comps on a Polo GTI in the uk.
    If the offset was 35 i think a 215/40/17 would be a good way to go.
    May 2007
    Burleigh Heads, Qld
    Nice wheels!
    kogarah
    I have 15 inch vw rimms with 195 tyres . Can i go to 205 or 215 tyres without upsetting things
    Sep 2007
    Thornlands, QLD
    215/40/17
    This seems to now give correct speed...at least according to the GPS
    Feb 2008
    Kincumber, NSW
    So what tyre size did you finally decide on the 205x40x17 or the 215x40x17?
    If you fitted the 215x40x17 - did they fit without any tyre scrubbing on either the suspension or inner guards.
    Reason for the question is that I have picked up a very good set of the optional VW "Siata" 17 x 7 wheels for my Polo GTI - and I am keen to know what works best.
    Obviously the 215 section tyre will give a meatier look - and given the 6% speedo error, I can live with the 2.2% variance to the gearing off the original 205x45x16 tyres
    Appreciate your views
