Results 1 to 10 of 11
Thread: Rear brake (256mm) upgrade
    Jan 2009
    blankedy
    I'm considering doing the rear brakes on the Polo for a few reasons
    - better braking
    - reduced wear on the front components
    - looking awesome (well, better)
    This would match the 312 setup I run in the front.
    Seems the Audi TT 225 kit is bolt up, which I can get for under 350 (used but usable pads and rotors).
    Thoughts?
    Jan 2009
    Anthony (VWindahouse) has the bigger rear set-up. Give him a nudge to add some input. When I drove his car after a track session the brake feel was far better than mine. Though that's also attrubted to braided lines, high temp fluid, etc. I think he was running the same pads as I was, though me on standard sized rotors.
    Daily: 2010 VW Jetta Highline
    Feb 2007
    Brisvegas
    Haha that they do! Well worth it mate.
    Had the rears on before the Brembo's (when Sean drove it a little) and they really help keep the rear of the car composed under heavy braking situations and they definitely take front end dip away you must have from the big 312mm front and OEM rear set up.
    Jan 2009
    blankedy
    Thanks gents.
    Jan 2009
    blankedy
    Jumped on it.
    I've had a few dealings with a mechanic / scrapper in the UK, if you are looking for parts, give him a go: LuxuryCarSpares@hotmail.co.uk
    In this case, I happened to ask him if he had what I wanted, in this case he did and does good postage for low cost. Costing me 110 pounds for the rear calipers, carriers, pads, rotors and dust guards, then 90 pounds in freight. By the time Paypal does a dodgy currency conversion, its a little under 340 pounds.
    Aug 2012
    Sydney NSW
    Jumped on it.
    Hi Ben.
    Did you mean 240 pounds?
    110+90 =200 pounds plus paypal addons = ?
    Mar 2012
    NSW & Romania
    200 pounds = ~AU$340
    Red 2006 Polo GTi : Forge Splitter - TIP - ITB - Forge Front & Rear Strut Bars - Dash Cubby - Fumoto Valve - Full Milltek Exhaust - PD160 Intake - K&N Panel - ECS Stage 1 Clutch - Seat RCA Bushes - APR Stage 1+
    Jan 2009
    blankedy
    Yeah, brain elsewhere, $340
    Mar 2013
    melbourne
    hi guys , I got a full set of mk4 r32 discs and calipers, what rear carriers are you guys using?
