Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
Thread: Tryes size for our Polo GTI
  1. #21
    Feb 2008
    Great find man.
  2. #22
    Thank you mate!
    Size Min. rim optimum Max. rim
    Width Width Width
    215/40ZR17 7.0 7.5 8.5
    So... IF the OZ rim width size is 8x17 and
    I'm still able to run 215/40 R17 ref. to the data...
    since the max width is 8.5??
    am i right?
    cuz I'm dump in rims size...
    thx mates!! really thx!!
    2013 4Motion "BLACK BEAR"
    http://blackbeartiguan.blogspot.hk//
  3. #23
    Quote Originally Posted by Timbo View Post
    You can run 8" rims IF they are of the correct offset and don't either cause rubbing or extend the type beyond the bodywork. A few people have fitted the 17x8 optional wheel that was supplied with the V6 Bora Sport. The problem is fitting a tyre wider than 205. I understand it has been done.
    Umm. I said LEGALLY.
    People should read this...
    http://www.rta.nsw.gov.au/registrati...vsi09_rev4.pdf
  4. #24
    Nov 2006
    I was being "LEGAL"!
    Why would fitting 8" rims, with the correct offset, to replace the Pog's standard 7" rims be illegal in terms of what is written in the RTA's "guidelines" (which is neither legislation or regulation, BTW)?
    However, all this is beside the point really, as 215's will fit 7.5" rims quite perfectly. Fitting larger than 215 will be the cause of headaches, methinks
    2015 White German SUV
    2013 White German hatch
    2011 Silver French hot hatch
    2008 TR Golf GT TDI DSG
  5. #25
    Feb 2007
    Brisvegas
    Standard polo rims are 16x6.5 not 16x7.
  6. #26
    Nov 2006
    Yes, but VW offers 17x7 optional wheels as factory approved options
  7. #27
    Aug 2008
    Problem is that the cops and RTA look at the standard rim size not the optional rim size (using the plackard on the car). So "Legally" you can only fit 7.5" rims to the car.
    Cheers,
    John
  8. #28
    Jan 2008
    Quote Originally Posted by JCM308 View Post
    Wrong.
    It's taken off the largest factory option wheel you can get.
  9. #29
    Apr 2008
    so do you guys think the polo would handle 225/35R17 without rubbing? and would that still be the case if its lowered with the H&R 35mm springs?
  10. #30
    225/35 R17 will be fine if you lowered 35mm
