Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
Thread: Tryes size for our Polo GTI
    Also i need to check if it cannot use
    215 40 R17 then i need to use 225 35 R17 for rubber
    2013 4Motion "BLACK BEAR"
    http://blackbeartiguan.blogspot.hk//
    Quote Originally Posted by VW GTI View Post
    Are they legit OZ wheels?
    Yes i need to check with them when it arrived!
    Double checked with the OZ website for Polo 9N
    http://www.ozracing.com/at-team/whee...11.2001/-17/en
    Superturismo GT - RACE SILVER + BLACK LETTERING
    SIZES ET PCD x HOLES AT CODE
    7x17 38 5x100 1 W0167220082
    8x17 35 5x100 1 W0167320082
    and check with polo9N.info
    if it is 8x17 ET35 I need to use 205/40 R17 or 225/35 R17
    If it is 7x17 ET38 I need to use 205/40 R17 or 225/35 R17
    215/40 R17 is only for Cross and Fun polo.
    Not sure it is legal to run 8 inch wide rims on the Gti. You are only allowed an extra inch on the maximum width on the tyre placard.
    Quote Originally Posted by pologti18t View Post
    Ya still need to wait for the wheel arrive and check with the tyre as well
    Nov 2008
    Wembley, WA
    A 205 tyre is 8 inches wide & is best suited to a 8" wide rim. Would there be a problem with that since they're already stock 205s on an under sized 6.5" stock rim?
    Sorry, not trying to hijack the thread - just interested as I am thinking of doing the same.
    Nov 2006
    You can run 8" rims IF they are of the correct offset and don't either cause rubbing or extend the type beyond the bodywork. A few people have fitted the 17x8 optional wheel that was supplied with the V6 Bora Sport. The problem is fitting a tyre wider than 205. I understand it has been done.
    2015 White German SUV
    2013 White German hatch
    2011 Silver French hot hatch
    2008 TR Golf GT TDI DSG
    Feb 2008
    Quote Originally Posted by mozzzy_2000 View Post
    Sorry mate, a 235 tyre is designed for a wheel which is 8in wide. 215 is for 7 in, a 205 is for 6.5in and a 195 is for 6in wide. Just remember that the tyre width(205) is a measurement of the inside between the 2 beads of the wheel, not between the outer surfaces of the wheel rims.
    S.E Melbourne
    Quote Originally Posted by Timbo View Post
    whats the correct offset though?
    Nov 2008
    Wembley, WA
    Quote Originally Posted by Blitzen View Post
    I was just referring back to what I had read & I must have misinterpreted what it was saying but they do mention as an example that a 205 tyre being 8" should be on at least a 7" rim or bigger. So perhaps a 205 on a 7" would be ideal and 7.5" would be pushing it but not impossible? Its interesting though because on the Oz wheels site they list several 8" wide rims as being suitable for the Polo 9N. It makes it hard to I guess because you don't actually know until you try to fit the wheel/tyre in the first place.
    Anyway this is what I read on Balance Motorsport:
    Generally speaking it helps to have a wider wheel. Assuming you are already running low profile tyres of a reasonable width you may benefit from increasing the rim width. For optimum performance it is good to have a rim as wide, or wider than the tyre. This will stretch the sidewall of the tyre making it stiffer and ensuring that there is less deflection of the tyre in the corner. This results in lower slip angles and a higher limit of adhesion. It will also reduce ride quality, and potentially make on limit handling less forgiving (you can rarely have your cake and eat it!). For example a 205mm tyre is 8 inches wide. So if you are running 205 tyres on anything less than a 7.0” rim you would benefit from a wider rim (Exactly the opposite is true of putting tyres wider than the rim). Before choosing your wheel you need to know your current offset and establish if you will have problems with the wheel fouling the arches or the suspension of the car. Fitting a wider wheel without increasing offset will possibly cause problems with clearance on the suspension components at tighter lock.
    Jan 2008
    Western Sydney
    You can see the "Optimum" rim width for each tyre size on the Michelin website - Here
