Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 107
Thread: Tramlining & Excessive Torque Steer.
    Aug 2007
    Quote Originally Posted by Eddy View Post
    Hoyhoy.
    I should also say that this is not just for Polo's, but a wide range of VW's.
    Not only Vw but Audi too, they all fall into this trap. Your man at the lathe is going to be busy i feel
    Jmac
    Alba European
    Nov 2008
    Nice work.
    Is your engineer friend interested in starting a production line for these ?
    I'll buy some if you head down that path.
    Feb 2007
    Brisvegas
    Yes please Eddy count me in, and these should end up a good little earner world wide.
    Jan 2009
    blankedy
    Where are you squeezing your Camber from Eddy?
    Also have some interest in the pins.
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Now thats another story on its own with many $'s & man hours spent there, the setting in the pic. is at -2 degrees for the road.
    http://
    Hooroo.
    Jul 2007
    Auckland, NZ
    Mass production! I will be keen...
    Well done Eddy!
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    Sep 2006
    Tweed Heads
    How much were the inserts Eddy? Can you get more?
    Hoyhoy.
    OK people, we have talked a little bit along these lines. Will get back to ya's.
    Its not just the camber pins, you need longer bolts (hard ones), 30mm slim line open ender which will have to be made as well. Also a 30mm socket for ajusting.
    Rough figures will be around 140 - 170 dollars with longer bolts & the spanner including GST, no socket, plus fitting which can be straight forward, but may need to ream the holes out if damaged.
    This price might scare a few off, hey, but its cheap for what it does.
    This engineer chap is from the old school, not on line & hard to get to answer the Ph. So I'm not sure on how to go about it as yet.
    How about I edit the opening post for those interested or start a new thread for a list of possiables,,,,, what ya's think.
    Hooroo.
    Feb 2007
    Brisvegas
    Thanks Eddy! Please add me in!
    Jan 2009
    blankedy
    Fantastic.
    Would also be interested in understanding how hard it is to get camber on the front (now that you've done all the hard work).
    What sort of labor time do you think would be involved? An hour-ish? If it is going to be a long install, the price of the components ends up being less relevant to me as I have to pay a mechanic more to make the change than the cost of the parts.
    Thanks Eddy, really good engineering and so greatful to you for sharing your findings.
    Sep 2006
    Tweed Heads
    Fantastic.
    Hoyhoy.
    Well theres a lot involved, cutting of strut tower top, narrow springs (story on its own) to be able to fit in the small strut tower, top end of the sway bar links has to be changed also, because it also hits on the 3 degree setting. Camber plates were round in shape, but have to be changed to a diamond shape. A lot of minor hand filing in the top part as well. Not much room in these little things.
    In hours don't know, weeks = heaps
    A long episode, me fussy & me like the BEAST the way she is now.
    Just to give ya an update of the lastest list of changes made.
    APR tune.
    KO4 Turbo.
    APR dog bone bush.
    APR turbo back exhaust.
    APR Front Mt. Intercooler.
    APR R1 diverter valve.
    Forge tip.
    Seat intake.
    K&N panel filter.
    Wheel spacers. 15mm. Front,,,15mm. Rear.
    Modified Forge front strut brace.
    Slotted standard brake rotors front & rear.
    Green stuff pads for the road & Ferodo DS3000's for track use along with upgrade fluid.
    Cut down front brake backing plates.
    Front brake ducting for cooling.
    Billet steel flywheel.
    EVO pressure plate.
    Peloquin L.S.Diff.
    KW V3's coil overs, modified & with heavier springs.
    Custom Camber plates by Extreme Motorsports.
    Custom made heavy front sway-bar. (24mm.)
    Lower Front Chassis Brace.
    Custom lower control arm bushes.(Custom 95 Enduro)
    Control arms bolted at rear bush to reduce movement.
    Custom sub-frame hanger bolt cam sleeves.
    A bit of trivia, the weight on the front wheels of the Pog is 790Kilos.
    Hooroo.
