Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 107
Thread: Tramlining & Excessive Torque Steer.
  1. #41
    Sep 2006
    Tweed Heads
    hoyhoy.
    The ball joints have a taper fit, there are easier ways.
    Hooroo.
  2. #42
    Jan 2009
    blankedy
    Hi mate,
    Any news here? I'm keen to get this fixed if I can, last wheel alignment did not come out right (pulling left) wondering if this might be a part of the same issue?
  3. #43
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Been slack of late, the little girl is parked away in the garage.
    I've been busy for a couple of months looking for a future income which is more on my mind at the moment,,, sorry folks.
    Saw the engineer last Thursday, now says he's waiting on the bolts he ordered before Xmas.
    Hooroo.
  4. #44
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Sorry folks for time it has taken, but their here.
    Now the main reason I went for this was because there was movement between the subframe & the chassis, now if you don't have movement there it might not make any difference in doing this mod.
    I do know it made a lot of difference to my Little Blue Girl.
    It can take a bit of fiddleing to fit these, but I made a mark on mine as to where they were & which hole they came from, I can remove the main crossmember out & put it back as it was.
    Another problem can be the holes in the subframe, if you have movement, it can damage the 18mm holes like mine did, for this you'll have to burrow a reamer, because you don't want to bash these sleeves in, you must be able to turn them for ajusting.
    They have been designed for the Polos, but might fit others.(Sleeves = 18mm dia. with a 12mm hole & the length = 50mm plus the collar.)
    This is the kit below that I have available, including a bent spanner to make it easier to ajust.
    Have about 20 sets available
    Price = $95.00 Plus postage.
    I do have PayPal if needed.
    http://
    Hooroo.
  5. #45
    Sep 2006
    Tweed Heads
    Hoyhoy.
    For the more serious boys, heres another little trick I came up with.
    I found the rear control arm bushes have to be located spot on to help reduce movement, so I went one further & bolted the rear bush (custom made 95 enduro),compliments from FULCRUM in Brissy, may sound strange but thats me, fussy.
    http://
    http://
    http://
    Hooroo.
  6. #46
    Jan 2009
    blankedy
    Good to see you again Eddy.
    Can you give us a little info on what is involved in fitting?
    DIY or Mechanic work?
  7. #47
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Can be DIY, thats up to yourself.
    Not a hard job but a bit fiddlely, I use extended car ramps & then put the main weight on stands. The main problem can be if the sleeves don't fit into the subframe holes, then you'll have to have the holes reamed out.
    Hooroo.
  8. #48
    May 2009
    S.E. Melb Vic
    pm sent cheers
  9. #49
    May 2009
    S.E. Melb Vic
    Done, Thanks for your work on this, just like to keep things tight. ssman
  10. #50
    Jul 2007
    Auckland, NZ
    Eddy! Been waiting for this... thanks!
    Pm sent.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
