Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 107
Thread: Tramlining & Excessive Torque Steer.
  1. #91
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by vwthunder View Post
    Spoke to the Guys at Pedders (pedders you say), tho it was a while ago. The guys at South Melbourne are great and really into performance cars, workshop is always full of great machines.
    Anyway I was telling him about them, and I was told how they use the slack in the subframe to make small adjustments if they need to when doing a allignment, and without small adjustments well makes the car harder to setup?
    Is this correct
    So these guys know about shifting the subframe. Does anyone know of anywhere else in Melbourne to get an alignment that includes this? I just spoke to a place and they talked about taking the car to a panel beaters for adjustment on a jig.
    BTW, I don't know if it was Eddy's subframe sleeves, the Whiteline front anti-roll bar or the camber plates/strut lengthening but my power transition clunk is totally gone (there are some new noises but camber plates, hey ) and the steering feel with my lower offset track rims is almost as good as with the stock rims
    Can't wait to hit the track on Cup day.
    Resident grumpy old fart
  2. #92
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Greg, with using the hex head on the sleeves it will move without any jigs, plus how can ya align on a panel beaters jig.
    Just keep moving the sleeves one or two @ a time until happy, it can take awhile.
    I marked where all the sleeves ended in each housing with a punch 1 to 4 (thats sleeve & housing), now its easy to pull the sub frame out & back in without a wheel alignment, except for toe.
    Hooroo.
  3. #93
    Oct 2010
    Melbourne, VIC
    Yeah, I know - it was just the excuse from the wheel aligner not wanting to have to do more than fiddle with tie rod ends
    That's why I'm trying to find someone who's serious about alignment.
  4. #94
    Any of these suckers left Eddy??
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
  5. #95
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Fair call Greg.
    Hooroo.
  6. #96
    Sep 2006
    Tweed Heads
    Quote Originally Posted by spraycanmansam View Post
    Hoyhoy.
    I don't have any kits left, sorry.
    Hooroo.
  7. #97
    Oct 2010
    Melbourne, VIC
    Sorry Sam - I nabbed the last set.
  8. #98
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Bulk buy might give me some inclination to do more.
    Hooroo.
  9. #99
    Jan 2009
    blankedy
    I would love to Eddy, just don't have the know how to do myself and my mechanic isn't up for this sort of Engineering.
    If I do make contact with someone decent, it will be on my list.
    Any new lap phenomena's for us?
  10. #100
    Sep 2006
    Tweed Heads
    Hoyhoy.
    No new lap times, not even bad ones.
    Will be back @ Waky on 29/11/12 (Speed off the Sreets with no offical timing) & then on the 1/12/12 with Circuit Club, (offical timing).
    Don't expect to improve times, but will be trying.
    Will be logging intake temps for peace of mind.
    Hooroo.
