Quote Originally Posted by Blue9N3 View Post
I get all the theory, but I just don't get the fuss about torque steer.
I've got non offset poly rear control arm bushes, will going poly on the fronts make much of a difference? ( the fronts are solid rubber aren't they?)
Torque steer is nasty, the more power you have. Won't be half as bad with poly rear bushes, as the direction of the wheels won't move much side to side, with bad road surfaces.
Flogged out stock ones, very different story.
Front bush is rubber and so pretty stiff already. Can't go wrong with more poly though.
