Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: timing pull
    Within the scope of the timing offset within custom settings. I think pulling 5 degrees isn't a biggie. It's wot. To refine a tune for no pull ever would take ages. Obviously you can use numbers that will never cause timing to be pulled, how much potential are you missing out on though. At least the ecu will let you look over the edge and as long as you don't jump off the cliff, it will hold on to you, so to speak.
    I often see timing pulled when the throttle has closed for a gear change, is that dangerous to the engine. I doubt it.
    nsw
    Yeah I agree. If you can only offset the base timing curve you'll be leaving power on the table if you're not pushing it in some spots. It just seems risky to live in that zone and erode that much of your safety net.
    The 0.8drgrees on throttle lift is weird
    I've even seen it on lift and coast. Yeah surely not risky - the ecu using it to stabilise engine speed and re idle the engine?
