Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 67
Thread: Time 2 Get ECU'd!!!
  1. #41
    Jan 2008
    Yeah, that information is outdated, from when the original tune for the 1.8T engine was released (a long time ago).
    I can assure you it's not soldered. I've watched Alex do it.
  2. #42
    Sep 2006
    Australia?
    Quote Originally Posted by j0n_GTI View Post
    The APR for the Polo GTI is just a reflash, not a solder type. I stood there while they uploaded it!
    Not just APR all mk5s and polos are flashed not soldered.
    mk3 and mk4 are soldered!
  3. #43
    Quote Originally Posted by DubSteve View Post
    Not quite true Steve, I can flash MK4s, just have to take the ECU out and do it on the bench.
  4. #44
    Sep 2006
    Australia?
    True Gavin I realised after I said it but I thought you could actual flash some ECUs.
    Nice to see that they can be bench flashed
  5. #45
    Jan 2007
    As for MK3's OBDI cars are just a plug in chip, as for OBDII cars the original chip must be removed from the board, a chip housing soldered and the new chip put into the housing. I believe this too is an option for MK4's.
  6. #46
    Sep 2006
    Australia?
    Which means that they still need to be soldered.
  7. #47
    Jan 2007
    No, not OBDI vehicles...
  8. #48
    Quote Originally Posted by Golf Houso View Post
    Most tuners fit a socket and a chip to do MK4s but Custom-Code have the hardware to flash the ECU with a bench lead.
  9. #49
    We can "bench flash" MKIV's & any PSOP memory type ME5 ecu's, but seeming the ECU has to come out of the car (and all MKIV's ran out of factory warranty some time ago) - what we do is install an APR EMCS module with 6 times the memory of the standard chip & has an onboard processor.
    They are hard soldered, not socketed, as sockets can come loose.
  10. #50
    Anyway - back to T- go's original post - Its a flash (ECU in the car), you get two programs included in the base price (Stock & performance), and you can choose options such as:
    Valet Mode (Locks speed & rev limits car)
    stock
    95 Ron
    98 Ron
    104 Ron (Race gas)
    Anti theft (immobilises the car)
    Security (does not allow program switching without a PIN Number first)
    You can add any of these as options at any time, and you switch between them all with your cruise control lever - no extra devices required, no flash counter change etc etc.
